2 members (Uncles51, Shardean),
50
Mod | | | Forums66 Topics128,021 Posts1,055,356 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2013 Posts: 73 | OK I have not been on here for quite a while since I got my old 61 GMC going but I have driven it quite a bit. right now I volunteered to swap a friend's 62 chevy 1/2 ton over to power steering. like a fool I assumed he had the correct steering box. that was probably my first mistake. I just removed the pitman arm from his original box and find the shaft measures about 1.085" where the shaft on the power steering box he brought me measures 1.240" and he has no idea what it came off of. all I have from it other than telling by looks it's a GM unit is the casting has the numbers 7802644 on I as well as a 13 below that. I can also tell that if I could find a correct pitman arm to match it to the pickup steering linkage I will also need to shorten the steering shaft from the column.that I could handle but is there anyone that might be able to tell me what the box is off of or what might help? Raymond | | | | | Joined: Nov 2013 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2013 Posts: 73 | OK I may have got lucky- I have another friend with the same model truck and he says he used a 73 blazer box. that is what I ordered and as a guess I ordered the one for a 2 wheel drive as well as the pitman arm. hopefully it will fit but if anybody has any clarification on that I'd appreciate it. Raymond | | |
