1 members (qside), 157 guests, and 2 robots.
Topics128,260
Posts1,058,343
Members48,485
#1129705 10/16/2015 2:09 AM
Does any one have a picture of the front bumper brackets for a 1950 1 ton panel
1950 one ton panel, 1959 half ton apache
Did you ever get the pic? I am lousy on the computer and end up wasting a lot of time. Old computer...slow boat to china internet...bad luck. Anyway, the brackets should be the same as the pickup...1/2 ton...till the 1 1/2 ton which was not really made. All of that type of stuff is 1/2 ton.
rod
Originally Posted by morabuffalo
. . . Anyway, the brackets should be the same as the pickup...1/2 ton...till the 1 1/2 ton which was not really made. All of that type of stuff is 1/2 ton.
rod
Section 7.836: Bar, Frame to Bumper, Attaching
It looks like 47-54 1-ton is different from 1/2 & 3/4 ton.
1947-54 1-ton are the same for all years.
Here is the "key" to bumper section numbers.
I found one it is a long flat piece of steel about 2.5 " wide and as long as bumper. It attaches with 4 bolts. Thanks anyway it is totally different than any of those pics
