3 members (Samantha, Otto Skorzeny, tesa), 337 guests, and 4 robots.
Topics128,162
Posts1,057,057
Members48,463
Engineering is going on for new brakes on the 1947 first series GMC EC-302 dump truck. Can someone tell me what the bore and stroke length of a stock master cylinder would be? Also, does the stock brake system, on these trucks, have a metering device to prioritize more pressure/flow from the master cylinder to the rear brakes? Or is the pressure equalized between the front brakes and the rear brakes?
Al
smile Alan
1947 (early) GMC EC-302 Dump Truck
Jimmy
More pix in Photobucket
3B Offline
Hy Big Al's, the bore of the stock master cylinder is 1 1/4" as to the stroke that is dependent on the pedal linkage and the brake shoe adjustment, suffice to say that the stroke available was more than adequate for the average driving conditions anticipated by the engineers who spec'd the system, hope that helps.
Al,
The pressure is equal throught the system. The amount of stopping power per axle was determined by the size of the wheel cylinder, the diameter of the drum and the brake shoe surface area.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
And as an old timer pointed out to me recently- there is no booster- the "boost" came from the really long foot brake pedal and the short leverage into the master cylinder.
'47 Canadian RHD 1.5 ton truck
anyoldiron,
FYI, the Hydrovac booster were first introduced in 1939 on the 1-1/2 & 2 ton trucks...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
