6 members (Bill Hanlon, fonz8261, Shaffer's1950, tclederman, Hotrod Lincoln, Charles in CA), 70 guests, and 3 robots.
Topics128,087
Posts1,056,376
Members48,442
I see some sites listing repro running boards as '41-'46, and some listing them as '39-'46. Are '39 running boards useable on a '41-'46 and what changed? Was it just a cosmetic change, or is there a dimensional issue with what I want to do?
They are different for sure: http://chevy.oldcarmanualproject.com/parts/1929_41/41cp210.html
The earlier trucks had wider rear fenders, which might be the reason the fenders are different. The also had different front fenders and a shorter wheelbase.
As Sput mentioned, 39 & 40 are interchangeable. 41 - 46 1/2 tons had a slightly longer wheelbase ( 115" vs 113.5" ). Front fenders also have a different shape where they meet the running boards.
1940 Chevy KC 1/2-Ton
The wheelbase and rear fender issues don't concern me, the truck is getting a flatbed. When you say they have a different shape at the front fender I take it that means it won't bolt up?
So the running boards were a good deal and I went ahead and bought them anyway. I can't comment on the rear fitment since I don't have rear fenders, but up front they are a bit different. They match up to ~60% of the '46 front fenders starting at the cab, but towards the wheel opening the early running boards are longer. They do look like they'll work with some trimming. Can't tell yet if I'm going to have to shift them forward or back any to meet the fenders properly, but it doesn't matter because the mounts need replaced anyway.
