2 members (WarEagle1, 1 invisible),
172
Mod | | | Forums66 Topics128,284 Posts1,058,522 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 46 Member | | Member Joined: Mar 2003 Posts: 46 | I AM PUTTING THE BED BACK TOGETHER. THE BED BLOCK KIT CAME WITH TWO RUBBER PADS AND WAS WONDERING WHERE THE RUBBER PADS GO? CAN ANYONE HELP? AND WHAT LENGTH ARE THE CARRIAGE BOLTS THAT GO FROM THE ANGLE STIPS THREW THE FLOOR AND BED BLOCKS TO THE FRAME. THANKS | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | | | | Joined: Mar 2003 Posts: 46 Member | | Member Joined: Mar 2003 Posts: 46 | IS TWO THE CORRECT NUMBER OF RUBBER PADS? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | every bed mount setup I've seen has a thin rubber pad at every mount point - stops squeaky gremlins - bolts are always just long enuff to have a 1/2" or so beyond tight nut
Bill | | |
