9 members (warlock, mick53, 55shaker, fonz8261, Ponchogl, RoadsScholar, Gdads51, Otto Skorzeny, 32Fordpuchoptop),
105
Mod | | | Forums66 Topics128,048 Posts1,055,626 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | Does anyone have suggestions on where to find a throttle return spring? Zenith carb. There is an eyelet on the linkage going up to the carb from the block. Looks like the spring attaches down at the base of the block. I also need to know where this spring attaches on the bottom. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There should be a clip that attaches to one of the oil pan bolts. It uses a long thin spring. You might find one at the hardware store or one of the specialty suppliers. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | Looks like I'm going to have to source me a spring AND that clip... | | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | Easy to fabricate. I took a small piece of flat steel,drilled two holes in it.I think I had to use a washer so the clip would clear the lip of the oil pan.I got a spring that fit from the hardware store.---Jack | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 41-53 Accelerator Linkage Return Spring Lower Clip The clip was not used from 54 and onwards. There was a hole in the side of the bottom pan, or the spring was attached to the water drain/outlet near the rear of the block. | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Gusco, I'll go out and take a look at my old 235 I took out of my truck and if there is a clip for the lower spring connection, I'll send it to you.
1959 3100 Apache Fleetside
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Gusco, I have the bracket for the spring. PM me your address if you want it.
| | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | You're awesome, thanks! i spent all day on the road picking up a new to me 235. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Tim, I hate to disagree with you, but the '55-'59 did use a clip for the throttle return spring. It is a different design than the one shown in your link, though. Throttle linkage '55-'59.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
