| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I ran out of gas and after refueling,the pump was not getting gas to the fuel filter and the carb. I tried priming the carb but no luck. This happened before and after several tries of priming it started with no further problems. Everything is new back to the tank except the pump. Is this an indication I need to replace it or would it be something else? Steve | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You could have gunk in the fuel tank, and there might be a blockage.
Try disconnecting the fuel line at the fuel pump. Blow air back to the fuel tank (gas cap loosened). If air blows/flows freely, connect the line back up, crank the engine, and see if fuel flows. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | With a full tank, remove the line to the pump. Gas should flow and make a mess. No flow? plugged. Gravity works well at this place. See post above to clear small stuff. If no joy, then pull line at the bottom of the tank. Careful, it will drain on you if not plugged. No flow? Plugged?. Push a stiff wire up into the tank to move the crud. Good times.
Steve H
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you find that you have crud in the tank (after following Steve & my directions/suggestions), it would be a good idea to remove your tank and clean it out (or, worst case, replace it). | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Tim, well I found the problem. There is a new NAPA filter between the pump and the tank. I pulled the gas line on the tank side and it "gurgled" a bit and then ran free. On that same side of the filter, there is a small crimp in the line. Could that have caused a vapor lock? I was starting to run out of gas as I explained above. Actually, I may not have been running out and instead it was the vapor lock and the engine stopping that made me think that. I have not solved the gas gauge problem yet. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do not know about vapor lock (unlikely) but a crimped line could easily block flow. | | |
