7 members (Gray_Ghost, Rusty Heaps, Brian Moore, 55shaker, Otto Skorzeny, Hotrod Lincoln, 1 invisible), 85 guests, and 2 robots.
Topics128,028
Posts1,055,414
Members48,422
#1129678 10/15/2015 11:02 PM
1954 235 Chevy engine. Has anyone ran a flex a lite fan?
1953 GMC 1-Ton Pickup with 350 and 700R4
Chad M #1129790 10/16/2015 5:49 PM
Are you talking about those "RV" fans at the local parts house? Make sure it is the same diameter as the fan you are replacing. Make sure it won't hit a hose or a pulley as it turns. There is more offset to the back than a normal fan so check it for any interference. I have one on a 55-62 235 with no issues. Your set up may be different.
Steve H
Chad M #1129813 10/16/2015 10:11 PM
Chad M #1129814 10/16/2015 10:24 PM
Have a flex fan on my '48. Works as advertised. Just make sure it doesn't flex enough to get into the radiator.
Chad M #1129825 10/16/2015 11:39 PM
Make sure you get the right sized spacer that you need and should be all good. Why are you wanting to run one on your 235? If you have the stock fan I would stick with that.
My 46 GMC on Photobucket
Chad M #1129830 10/17/2015 12:32 AM
Thinking about more top-end power. My truck loses a lot of speed going up hills.
Chad M #1129835 10/17/2015 1:38 AM
I don't think that 1/100th of 1 percent increase in horsepower will get you up the hill any faster.
My 2 cents, refundable at major banks and Saving and Loans.
Carl
Chad M #1129858 10/17/2015 3:29 AM
Yeah, putting on a flex fan isn't going to gain you anything noticeable in the power department. Best keep your dollars in your jeans on that one.
Chad M #1129896 10/17/2015 1:55 PM
Anyone ever try a clutch fan? GM brand of course...
1947 GMC Truck 5 window, Long Bed
2008 Corvette Roadster
2008 Harley Davidson FXDL
2011 F150 Ecoboost 4X4
2015 Subaru Outback AWD
"only the strong survive"
ctheusa #1129980 10/18/2015 2:04 AM
H Online: Content
Not nearly enough room between the water pump and the radiator for a clutch fan.
Chad M #1130434 10/20/2015 5:47 PM
The only advantage to the flex fan, it was available. The fan I had was cracked, so looking for a fan was sort of what can I find. Now I have a spare stock one, but changing it will require removing the radiator, so it might stay for a bit.
Steve H
