Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Joe H, KEVINSKI, 3B, 1 invisible), 87 guests, and 7 robots.
Topics128,274
Posts1,058,436
Members48,490
Does anyone have suggestions on where to find a throttle return spring? Zenith carb. There is an eyelet on the linkage going up to the carb from the block. Looks like the spring attaches down at the base of the block. I also need to know where this spring attaches on the bottom.
Riding in the Passing Lane
There should be a clip that attaches to one of the oil pan bolts. It uses a long thin spring. You might find one at the hardware store or one of the specialty suppliers.
1972 Chevy c10 Cheyenne Super
Looks like I'm going to have to source me a spring AND that clip...
Easy to fabricate. I took a small piece of flat steel,drilled two holes in it.I think I had to use a washer so the clip would clear the lip of the oil pan.I got a spring that fit from the hardware store.---Jack
41-53 Accelerator Linkage Return Spring Lower Clip
The clip was not used from 54 and onwards. There was a hole in the side of the bottom pan, or the spring was attached to the water drain/outlet near the rear of the block.
Awesome! Thank you
Gusco, I'll go out and take a look at my old 235 I took out of my truck and if there is a clip for the lower spring connection, I'll send it to you.
1959 3100 Apache Fleetside
Gusco, I have the bracket for the spring. PM me your address if you want it.
You're awesome, thanks! i spent all day on the road picking up a new to me 235.
Tim, I hate to disagree with you, but the '55-'59 did use a clip for the throttle return spring. It is a different design than the one shown in your link, though. Throttle linkage '55-'59.
Bill Burmeister
