| | | Forums66 Topics128,037 Posts1,055,470 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hey Guys,
When sanding down to bare metal, is it recommended to use the metal prep phosphoric acid treatment? If I do this can I use epoxy primer on top of this? I read in another post that you should not do this because the acid will leach through the epoxy. When I have used the Por-15 I have used the metal prep before applying the paint. It seems that sometimes it is almost impossible to get the surface 100% clean with out some small rust pits or scratches. how do I prep the metal to have a super clean new metal surface?
thanks, skipper | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | All major paint manufacturers sell a product like this. They all recommend washing off the product. You can trust wikiwhatever or the manufacturer. This guy decided to test the idea on his own. Now you can decide for yourself.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You tell 'em CASO!!!! I don't have the time nor inclination to get into a pizzin' contest today1!! dg
Denny G Sandwich, IL
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Lacquer paint ain't Epoxy Denny. Don't confuse people with Apples and Oranges comparisons. That's just throwing mud at a window to help visibility Here is PPG's own product sheet telling how THEY want it done. You'll please notice that while they say in Step 2 (DX520) you can "rinse well and dry" in Step 1 they want the First product (DX579) applied with a scuff pad over an already cleaned (rust etc.) surface, then while it is still wet (notice no mention of letting the DX579 dry before the DX50) the next step begins. Their product is just another formula of phosphoric and other acids and wetting agents similar to Ospho or Metal Prep.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I read it as scrubbing only Galvanized or Gavaneal metal which I didn't think that rc356s was asking about. Am I interpreting this wrong?
Drew
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | You're correct Drew the 'pad' speaks to galvanized or galvanneal. The products are both washed off while the acid/'product' is still active/wet just the same.
Above the chart under "Application" they also say that the surface should be "abraded" and "all contaminants" removed before applying the product. That would either be a solvent based grease remover as well as a water soluble wax and grease remover, or at least a 'hot' soapy water and rinse in my understanding of removal of 'contaminants'.
