| | | Forums66 Topics128,105 Posts1,056,209 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2014 Posts: 34 | Hey guys just wondering if a 1954 front fender would work on a 1951 gmc? | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Not without some serious fabrication. There are some significant differences under the headlight area on the 54 for the grill extension in that area. Carl
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | You can mount the entire 1954 Chevy front clip on your 1951 GMC. Where the fenders bolt to the cab, is the same on 1947-55 GMC and Chevy cabs.
You can't mix fenders and grills. You have to use the entire front clip from ether a: 1947-53 Chevy truck or a 1954-55 1st series truck
Definition of front clip: Two front fenders Fender skirts and supports Front grill and radiator supports
Also you can mount the entire front clip from a GMC truck onto a Chevy truck.
If you do the clip swap the only way to tell if it is a Chevy or GMC is to look at the interior dash. | | |
