8 members (Bill Hanlon, Jon G, 55shaker, Otto Skorzeny, HandyAndy, UtahYork, DadsFirstPickup, Hotrod Lincoln), 78 guests, and 3 robots.
Topics128,036
Posts1,055,448
Members48,422
#1129086 10/12/2015 7:34 AM
Hey Guys,
When sanding down to bare metal, is it recommended to use the metal prep phosphoric acid treatment? If I do this can I use epoxy primer on top of this? I read in another post that you should not do this because the acid will leach through the epoxy. When I have used the Por-15 I have used the metal prep before applying the paint.
It seems that sometimes it is almost impossible to get the surface 100% clean with out some small rust pits or scratches. how do I prep the metal to have a super clean new metal surface?
thanks,
skipper
rc356s #1129116 10/12/2015 2:55 PM
All major paint manufacturers sell a product like this. They all recommend washing off the product. You can trust wikiwhatever or the manufacturer.
This guy decided to test the idea on his own.
Now you can decide for yourself.
Give me ambiguity
or give me something else
rc356s #1129254 10/13/2015 11:00 AM
You tell 'em CASO!!!! I don't have the time nor inclination
to get into a pizzin' contest today1!!
dg
Denny G
Sandwich, IL
rc356s #1129300 10/13/2015 4:33 PM
Lacquer paint ain't Epoxy Denny. Don't confuse people with Apples and Oranges comparisons. That's just throwing mud at a window to help visibility nono
Here is PPG's own product sheet telling how THEY want it done.
You'll please notice that while they say in Step 2 (DX520) you can "rinse well and dry" in Step 1 they want the First product (DX579) applied with a scuff pad over an already cleaned (rust etc.) surface, then while it is still wet (notice no mention of letting the DX579 dry before the DX50) the next step begins.
Their product is just another formula of phosphoric and other acids and wetting agents similar to Ospho or Metal Prep.
Give me ambiguity
rc356s #1129398 10/14/2015 3:09 AM
I read it as scrubbing only Galvanized or Gavaneal metal which I didn't think that rc356s was asking about. Am I interpreting this wrong?
Drew
rc356s #1129405 10/14/2015 4:00 AM
You're correct Drew the 'pad' speaks to galvanized or galvanneal. The products are both washed off while the acid/'product' is still active/wet just the same.
Above the chart under "Application" they also say that the surface should be "abraded" and "all contaminants" removed before applying the product.
That would either be a solvent based grease remover as well as a water soluble wax and grease remover, or at least a 'hot' soapy water and rinse in my understanding of removal of 'contaminants'.
Give me ambiguity
