7 members (Phak1, moparguy, Chooglin, 54farmtruck, 2-Ton, GMCJammer51, WICruiser), 47 guests, and 2 robots.
Topics128,151
Posts1,057,004
Members48,460
#1129197 10/13/2015 1:14 AM
Gas Pumper
Gas Pumper
The 1947-1955 Harrison Deluxe Heater has a few small parts that our regular vendors do not seem to carry. One of them is the two rubber bumpers that are inside the heater that keep things quiet when you turn the defroster knob. They are 1/8" and I found two sources that I want to share so the next time someone needs them, they can search here to find them.
www.marshallshardware.com
0505510 Rubber Bumper 1/8x5/16x11/64
http://www.marshallshardware.com/pr...0%20%20%20%20%20&kw=0505510&st=0
www.steelerubber.com
p/n: 33-0127-41 Rubber Bumper 1/8x5/16x5/32
http://www.steelerubber.com/glovebox-and-fuel-door-bumper-33-0127-41
Both will work great. I do not have both to compare, but the Marshals offering is .69 cents each, while the Steele Rubber ones are $1. We all know that Steele Rubber is very hard to beat in quality.
The part I am having more trouble with is the 1953 Heater with the extra dual closing doors. There is a rubber blade that goes across the larger door. Haven't found that one yet. Hope this helps someone down the road.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
You mean I wasted my time making a mold copied off the original
bumper and then vulcanizing them when I could have bought them
for a buck?
http://www.pbase.com/dennygraham/image/134930871
dg
Denny G
Sandwich, IL
Deve
Wow, newbie here and wasn't aware of either Marshall's or Steelerubber. Both sites are loaded with all kinds of great items.
Thanks so much for the links!
Jeff
Gas Pumper
Gas Pumper
Very impressive Denny! This is the sort of ingenuity that is hard to find. The thought of making my own rubber bumpers wouldn't even occur to me. Were you a bootlegger in your past life? Someone has to make the stopper that goes in the top of the bottle! Seriously amazing!
Deve
The Think Tank
Gas Pumper
Gas Pumper
I found a 12v heater motor that is listed at Chevs of the 40s as the very same outside dimensions as the original 6 volt motor. Since this isn't normal, I ordered one. I needed it anyway so good time to find out. No Cigar! Same dimensions as all of the 12v motors out there. As I normally do, I will put the 12v motor inside the 6 volt case and do the usual thing. The part number on this motor is VDO PM354. Since this is a big issue because the motor has to look right on the firewall, at least we have a way to do it without going to huge lengths.
Deve
The Think Tank
Moderated by  ndkid275, Phak1
