2 members (68ironhead, stlcardinalsguy), 187 guests, and 14 robots.
Topics128,078
Posts1,056,036
Members48,433
#112878 01/15/2002 11:09 PM
I see eastwood has these free standing infrared curing lamps that you use on large pieces. In addition to my normal job I part own our family restaurant. We have a lamp that uses those large infrared light bulbs to keep the french fries warm. Every one has seen them looks like out door flood bulb. Those things get pretty hot, got the scares to prove it. Wonder if that would work to powder coat large pieces. Any one know or have a suggestion on how to powder coat a large object? Thnaks! cool
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces
2000 GMC Serria 1500 SL 4x4
rat Offline
When you powder a large piece, after you powder you start to heat from the bottom up. You have to get the piece 400deg for about 5-10 minutes. It takes 5-10 minutes to get the piece up to temp. but once the first spot is up to temp. the spot right above is already starting to heat up and cure so it starts to go faster. It still takes longer to powder than to paint but it all depends on what you want.
'52 Chevy 5 window, it ran when I parked it
'53 Chevy 5 window, running the streets with me.
'55 Massey-Ferguson, tearing up the dirt
'89 Harley FXSTS, suicide clutch
'92 Harley FLSTC, equal time with the '89
Thanks Guess Iam going to have to give up on the black chrome look. and go with ol plan jane regular chrome. Thanks again!
