0 members (),
145
Mod | | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | I see eastwood has these free standing infrared curing lamps that you use on large pieces. In addition to my normal job I part own our family restaurant. We have a lamp that uses those large infrared light bulbs to keep the french fries warm. Every one has seen them looks like out door flood bulb. Those things get pretty hot, got the scares to prove it. Wonder if that would work to powder coat large pieces. Any one know or have a suggestion on how to powder coat a large object? Thnaks!
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces 2000 GMC Serria 1500 SL 4x4
| | | | | Joined: Feb 2000 Posts: 50 Member | | Member Joined: Feb 2000 Posts: 50 | When you powder a large piece, after you powder you start to heat from the bottom up. You have to get the piece 400deg for about 5-10 minutes. It takes 5-10 minutes to get the piece up to temp. but once the first spot is up to temp. the spot right above is already starting to heat up and cure so it starts to go faster. It still takes longer to powder than to paint but it all depends on what you want.
'52 Chevy 5 window, it ran when I parked it '53 Chevy 5 window, running the streets with me. '55 Massey-Ferguson, tearing up the dirt '89 Harley FXSTS, suicide clutch '92 Harley FLSTC, equal time with the '89
| | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | Thanks Guess Iam going to have to give up on the black chrome look. and go with ol plan jane regular chrome. Thanks again!
