1 members (DHedrick),
317
Mod | | | Forums66 Topics128,158 Posts1,057,023 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 4 'Bolter | | 'Bolter Joined: Feb 2005 Posts: 4 | The 6.50-16 tires are completely shot on my '47 1/2 ton. Buying new Cokers are completely out of the question on this poor man's budget. I do have a set of 3 clip 15" wheels that measure 5.5" wide. The '47 does have lever shocks which I am keeping. The edge of the wheel clears the shock lever and the steering linkage by about an inch. Can anyone suggest a common size 15" radial so I can continue driving my '47 with the lever shocks a couple of hundred miles a year? Thanks | | | | | Joined: Dec 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 54 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Obsolete size. 215/75/15 is about the biggest that will work on those wheels.
Bill Burmeister | | | | | Joined: Feb 2005 Posts: 4 'Bolter | | 'Bolter Joined: Feb 2005 Posts: 4 | Thanks, I know I can run 215/75/15 with the tube shocks, did it on a '51. My main concern is the lever shocks and the link and clearance on the tires.
http://www.flickr.com/photos/11935732@N07/
| | | | | Joined: May 2009 Posts: 85 'Bolter | | 'Bolter Joined: May 2009 Posts: 85 | My 49 3100 has lever shocks and I have run some 15 inch wheels from a 48 or 49 car with no problem. Did have bias tires though.
1949 3100
