0 members (), 59 guests, and 3 robots.
Topics128,206
Posts1,057,438
Members48,471
dbt
Offline
1949 Chev. 2-ton. Got it some time back. Did not run; had been sitting for unknown time in driveway in town. Before I tried anything I pulled rocker cover and found a bent push rod. Top of head pretty well free of gunk and looked oily and decent. I squirted ATF/diesel down all the push rod holes and a little oil in cylinders. Have not tried to turn engine over. I've not dealt with bent push rods before. Two questions:
1: What typically causes bent push rods?
2. How do I begin to deal with this so as to be kind to the engine?
Stuck valve from sitting a long time is one possible cause.
Get a can of KROIL (www.kanolabs.com) and squirt a liberal amount on the valve stems through the springs. Let the engine sit a few days and oil it down again. After 2-3 applications, use a small hammer and tap the tops of the rocker arms above the valves to get the valves moving, then start working the rockers up and down with a short pry bar to help free up the valves in the guides. While you're at it, put an ounce or two of KROIL into each cylinder through the spark plug holes.
Pull the flywheel cover behind the oil pan and use a short pry bat on the ring gear teeth to rock the engine back and forth a little at a time until you can make a full turn in both directions before you try to spin the engine with the starter.
If the valve was seized enough to bend a pushrod, there's a good possibility you'll end up pulling the head and getting a valve job done, but go ahead and try to do the quick fix and free it up. It works about half the time.
Edit: If it's a 49 model with a 261 the engine must have been changed. The original engine would have been a splash-oiler 235.
Starting with stale fuel probably caused it.
dbt
Offline
Thanks everyone. I'll do that. In some ways, I've already begun. And I'm in no hurry, so I should be able to get quite a lot of lube in this motor. I remember my dad doing valve grinds on engines and after installing valves, springs and their keepers he'd take a little block of wood, set it on the end of the valve stem, and give each a rap with a hammer. I think he felt that, "set," the keepers and gave him a verification it all was in place. Good idea I think. I have a tool for turning the flywheel at the ring gear, so I had already thought I'd pull the dust cover under the bell housing and start working the crank back and forth a little at a time. Thanks again, Dennis
