| | | Forums66 Topics128,108 Posts1,056,558 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | Hi I just purchased a 1954 - 3800 and the front two tires are shot. I was wondering the best place to get replacements or equivalents? They read 7.00-17 (one is 8 ply and the other is 6 ply) in size. Thanks!
1942 BK 1/2 Ton Pickup 1954 3800 1 Ton Pickup
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | I believe the only domestic tire company still in business is Specialty Tires of America. Coker and other vendors market the tires for STA. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | 17" tires off of a late model 3/4 or 1 ton GM pickup with 16" radial tubes work fine for me. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Crenwlege, So you put modern radials on your stock 17" rim with a 16" tube, correct? What size tire did you use? | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | The tires that were OEM on my 2012 2500HD. I now have a 2015 3500HD Dually flatbed with the same size tires. It has always been common practice to use smaller tube to keep tubes from folding. Back when I still ran trucks with tube required tires, probably half the flats were from folded tubes. I was able to salvage my old flaps. But a flap can be made from an old tube. Just anything to keep the tube from rubbing on the wheel. | | |
