| | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 37 | I currently have halogen 12V headlights in my truck and they are not real bright (truck is 49-3100 all 12V) is there a better choice that is brighter or is HID the next step. THANKS AGAIN ! ! ! !
| | | | | Joined: Sep 2015 Posts: 15 New Guy | | New Guy Joined: Sep 2015 Posts: 15 |
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Heavy duty relays and very good grounds might solve your dim light problems without going to the super bright headlight bulbs. The dimmer switch in particular is a source of resistance that can dim the lights noticeably, particularly if you're still using the original equipment floor-mounted one. Check the actual voltage at the headlight bulbs, compared to battery terminal voltage, then find the source of the voltage drop if the lights are getting noticeably less than charging system voltage. Jerry
| | | | | Joined: Sep 2015 Posts: 15 New Guy | | New Guy Joined: Sep 2015 Posts: 15 | OK, now you've piqued MY interest  What should I do about the floor switch? I'm quite certain it's the original one.(Hell, the coil is, and the generator has been rebuilt once in 59 years.) Recommendations? Thanks | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The floor switch is fine except it gets dirty due to its location. Dirt causes the contacts to get more and more resistive. Clean the switch with electrical contact cleaner or get a new switch. Same for relays or anything else involved. Clean and dry with good properly gauged wires will make a world of difference. | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | What should I do about the floor switch? First thing first- - - - CHECK THE VOLTAGE AT THE HEADLIGHTS! Everybody wants the quick fix. Back in the dark ages, Sun electric Co. had a slogan on all their machinery: "We test, not guess!" If there's a noticeable voltage drop that you can definitely attribute to the dimmer switch by checking the voltage before and after the switch, replace it. Don't waste time trying to clean it up. Ditto for the headlight switch at the dash. You can avoid a lot of problems with headlights the same way it was done 70 years ago- - - -install relays that provide full battery voltage to the lights, and use the headlight switch and dimmer switch to control the relays. Heavy wires are run from a good source of voltage such as the battery cable at the starter to a junction block near the headlights, and relays are installed to direct that voltage to nothing but the lights at the proper time. No series of connections through the headlight and dimmer switches, and no small-gauge wires to rob voltage along the way. It worked on 6V systems in the 1940's, and it will work just as well today. Don't forget to run a heavy ground wire from both headlight connectors to a clean, low-resistance point on the body or frame. Or, you can pay some highway robber an outrageous sum of money for "bright" headlights which, BTW, use the same system of relay controls I just described. "Ya pays yer money and ya takes yer choice!" Jerry
| | | | | Joined: Sep 2015 Posts: 15 New Guy | | New Guy Joined: Sep 2015 Posts: 15 | Got it. I hadn't gotten to hooking up the relays, at which point I would've figured out that the high beam switch also ran through the relays. | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | The nice thing about using the relay system is that only a tiny trickle of current is routed through the light switch and dimmer switch for controlling the relays. The actual electric power for the headlights goes through heavy conductors direct to the relays, then follows a very short path to the lights and then another short path to ground. Jerry
