8 members (baldeagle, Woogeroo, Nick in Manitou, Jon G, FAST55, Hanks custodian, mick53, 50Chevy3100), 62 guests, and 2 robots.
Topics128,014
Posts1,055,332
Members48,419
#1127225 10/01/2015 2:28 AM
Help!
Trying to figure out what engine my truck has?
Casting number on block behind distributor is 333384!
Crusing in the Passing Lane
Px? What kind of truck? Stamped numbers are more useful.
If it has the original engine, a 4100 series truck would have a 216ci Thriftmaster engine. 235 was available as an option in the 4400 series trucks.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Take a wire brush and look again at your casting number...you gave us 6 numbers when most are 7. Also make sure some of your 3's aren't 8's.
As Ed mentioned read the stamped numbers that are on the machined pad near the distributer.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Are there any number letter combinations after that number?
Is there another number down lower below fuel pump or to the left. That number doesn't seem to compute with Tim's site. It is an excellent source. Tims site
Allen
1974 Stingray Corvette
Here are locations of various engine codes. Post the codes you find on your engines and people here will help you ID your engine.
Do you have an engine with a 2 bolts through the top of the valve cover or 4-screws at the base of the valve cover?
I think 6-cylinder blocks up to around 1940 had 6 digit casting codes, but your numbers do not match the codes I have found on various casting-code lists. If the code you posted is an Engine Serial Number (a code pressed into the block), early Engine Serial Numbers usually had 7 digits until around 1940 (as Mike posted above,). After that, ESLs were a combination of numbers and letters.
You most likely have a replacement engine. Post the castings codes so that we can provide better advice/speculation.
