BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,780 Posts1,039,295 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | Gas Pumper Joined: Dec 2000 Posts: 3,399 | It was corrected right away. All you have to do is read the article. I know you are one of the vendetta crew so I know you won't read it, you will just try to find stuff that's wrong. But DO read it, find things that are wrong and we can correct them so things are even more accurate. That is what sharing is all about. Do you know how many people that article helps? And much of it is thanks to you indirectly. Your input mixed with many others helped guide me in the right direction. Lets all just STEP AWAY FROM THE WRENCHES!! | | |
