0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | The truck is really starting to take shape. Most of the body work is done and will be spraying with primer this week. The grey pics are of poly surfacer, what an awsome product, fills in all the scatches and is very easy to sand. Had my running boards sprayed with truck bedliner and am very happy with te way they turned out. Ended up spraying inner fenders, under cab and interior of cab with a do it yourself bed liner. will put peel and seal self adhesive roll roofing product over top of this and should keep road noise to a minimum. Into body work now for 25 grand and should be about 40 grand total for complete truck. Was ether this or spend 50 grand on a new truck that you can't even repair yourself without a very expensive dignostics computer. Have a look at pictures here http://pg.photos.yahoo.com/ph/sublime589/my_photos | | |
