2 members (dt235sd, Peggy M), 76 guests, and 2 robots.
Topics128,130
Posts1,056,713
Members48,454
I'm a little confused as to what I need parts-wise for shocks. I read in one Stovebolt post that I need Monroe accessory pack (adapter) AK32 for the front, but when I tried to search it, that part came up as obsolete. It looks pretty clear to me: Remove bolts, remove and replace unit. Monroe also says I need "parts packs" P572&P576. Those don't appear, even on their own site.
Voluminous searching has only confused me more. A little clarification would be appreciated. Thanks
U
U Offline
This worked for my 55.2 3100. I got shocks at a local parts store, but I ended up returning & getting all four from Summit with a limited 50%-off sale. ($40 vs. $80). I like to keep business local, but $40...
You'll probably want some rubber bushing - safe lube; the new shocks will fit tight. Edit- there are two types of shocks you probably read about. I'm referring to the 1-1/2" to 2" (est.) 20" long (again, estimated) cylinders (4 total) that mount on front & rear.
Brad
Wrench Fetcher, PhD
Get a set of Gabriels, they come with all the proper mounting hardware.
Bill Burmeister
Thanks for the replies, y'all. I'll just order the shocks and worry about other eventualities if they occur. The 59 year old mounting bolts and nuts are soaking in PB Blaster as of last Friday smile
