9 members (Charles in CA, dt235sd, jmoore, Jay R, Southerntruck, Flatblu4748, tclederman, 5cameo8, 1 invisible),
72
Mod | | | Forums66 Topics128,128 Posts1,056,683 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 15 New Guy | | New Guy Joined: Sep 2015 Posts: 15 | I'm a little confused as to what I need parts-wise for shocks. I read in one Stovebolt post that I need Monroe accessory pack (adapter) AK32 for the front, but when I tried to search it, that part came up as obsolete. It looks pretty clear to me: Remove bolts, remove and replace unit. Monroe also says I need "parts packs" P572&P576. Those don't appear, even on their own site.
Voluminous searching has only confused me more. A little clarification would be appreciated. Thanks
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Remove bolts, remove and replace unit. This worked for my 55.2 3100. I got shocks at a local parts store, but I ended up returning & getting all four from Summit with a limited 50%-off sale. ($40 vs. $80). I like to keep business local, but $40... You'll probably want some rubber bushing - safe lube; the new shocks will fit tight. Edit- there are two types of shocks you probably read about. I'm referring to the 1-1/2" to 2" (est.) 20" long (again, estimated) cylinders (4 total) that mount on front & rear. Brad Wrench Fetcher, PhD | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Get a set of Gabriels, they come with all the proper mounting hardware.
Bill Burmeister | | | | | Joined: Sep 2015 Posts: 15 New Guy | | New Guy Joined: Sep 2015 Posts: 15 | Thanks for the replies, y'all. I'll just order the shocks and worry about other eventualities if they occur. The 59 year old mounting bolts and nuts are soaking in PB Blaster as of last Friday
