4 members (baldeagle, Jon G, Oswald, 1 invisible),
57
Mod | | | Forums66 Topics128,015 Posts1,055,334 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 9 New Guy | | New Guy Joined: Sep 2015 Posts: 9 | Hi, guys What are my options for getting slower rpm's at cruising speed? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Engine? Trans? Truck size? Routine use? Disc brakes?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In general:
- lower-ratio rear end - lower high-gear ratio transmission - larger diameter tires - drive downhill as much as possible
Post anwers to EdPruss's questions - people will post opinions/options. | | | | | Joined: Sep 2015 Posts: 9 New Guy | | New Guy Joined: Sep 2015 Posts: 9 | My truck has a 235 ( I think) 4 speed transmission, general use, no hills in southwest kansas so downhill is not an option! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Engine? = 235 (or, maybe 216) - what is the engine serial number?
Trans? = 4-speed - 1949 4-speed SM420 - open or closed driveshaft?
Truck size? - ?
Routine use? - general use, no hills in southwest kansas so downhill is not an option
Disc brakes?- original 1949-style brake system? | | | | | Joined: Sep 2015 Posts: 9 New Guy | | New Guy Joined: Sep 2015 Posts: 9 | Dont know the serial#. Original 4 speed open drive shaft. Truck size is 4100. Original brake system | | | | | Joined: Mar 2011 Posts: 107 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 107 | Getting them to go faster can be accomplished in a number of ways, and many folks on the board have used various methods with success. It must be remembered that once you start making modifications for speed, upgrades to the braking system should be strongly considered. Also, the power requirement to maintain higher speeds goes up dramatically and you might find your stock engine struggling. All that said, there are a number of options. Although I'm not that familiar with the 4100 size: There are several 5 speed transmissions with an overdrive that can be installed, with varying amounts of modification needed. The rear axle can be changed with one from a more modern truck to obtain a better axle ratio. It might also be possible to add an auxiliary transmission or overdrive unit to the truck between the stock transmission and the rear axle. I'll leave the model numbers to another member with swap experience. I don't always have luck with the search feature, but there are past posts available covering many options.
Someone will chime in with more options and some specifics about how to accomplish the various mods. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Like said above, disc brakes might be nice for increased speed.
Some Saginaw 4 speeds with side shifter arms also come with an OD on the rear. I don't know the MN, someone here will no doubt chime in.
| | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Get everything in good shape first before modifying a bunch of stuff. My 46 2-ton will run on the interstate at 55. I have seen it above 60 but the engine was not sounding good. The only modifications I have made are to the brake system. As said above, you must be able to stop if you plan to go faster.
| | | | | Joined: Sep 2015 Posts: 11 New Guy | | New Guy Joined: Sep 2015 Posts: 11 | I've just never been in that much of a hurry to where I had to push an old truck. If I get in that much of a hurry, I failed to plan  The old '48 GMC and '51 F8 I drove when I was a kid, I don't think I ever got em up over about 35. No need to. Besides, if I broke it with too much speed, I'd have to answer to Dad! (That lesson stuck) They were designed to go 40-50 miles an hour, tops, and go forever that way. They do a great job at it, too!
Bill South Texas Gulf coast 1950 Chevrolet 6400 with steel dump bedPics here | | |
