2 members (J Lucas, Sjm),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,285 Posts1,058,534 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 71 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 71 | hello
i hope to install an under bed tank in my 65 short step, what is the correct size and type of fuel line i should use. i see there is an intermediate section of metal line running in the rails, must the entire line be metal of can i use rubber fuel lines?
thanks | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The correct way is to have a flex line at the tank and carb with steel line between them. 5/16 should be fine for a 283. With that said, GM in the 60's or 70's on Buicks (and maybe Olds) use rubber fuel lines period--no metal.
Evan
