2 members (Patharr, 1 invisible),
45
Mod | | | Forums66 Topics128,090 Posts1,056,027 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Need some help with pics Anyone installing a jaguar front suspension in their 47-53 Chevy trucks?? I going to attempt to install a jag front IFS in my 52 Chevy truck Looking for pics of one bolted in to the frame and as many details as possible Brackets home made of store bought measurements from front of frame to center of crossmember what type of master cylinder brake lines . Thanks in advance . Robert
This is no longer fun
| | | | | Joined: Mar 2009 Posts: 9 New Guy | | New Guy Joined: Mar 2009 Posts: 9 | I put the front and rear of a 1986 jaguar in my 52 3600. It's all bolt in now with custom made brackets. I will try to post pics this weekend. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | There are several other posts about this right now. Might want to search for some of those other threads. | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Do a search for project xj-pu-v12. A guy has done a frame up build to install the entire drive train from a Jag under a late 30s early 40s truck. Absolutely amazing work. He has about 300 pictures of the build on photobucket.
Larry
| | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | thanks going to do a search right now
