1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 22 'Bolter | | 'Bolter Joined: Feb 2015 Posts: 22 | On my 59 Apache step side, looking for a replacement key switch. All I can find have OFF - ON - START. My truck has stomp start, so I don't need a start circuit. Slide connectors on the back don't match up to new switches anyway.
Like to keep it as close to original as possible....
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Ebay. You'll want Delco-Remy Ignition Switch (GM)1116522 (Delco)D-1406. It may be different for '59, so do your homework on that.
Take your current switch out, and look at it to make sure the terminals match up to anything you purchase. If it is original, it should have a number on it (mine says "522")
Brad Wrench Fetcher, PhD | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | UB, I believe the GM number is 1116522 (55-59 COMM., UTIL. (6 cyl.)(12 volt)(exc. DD, H.T.). Tobztub59, PM me if you are interested in a good used 522 switch. Mike B  | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Yep, Mike has the correct part number listed. Thanks for catching that one...
Brad Wrench Fetcher, PhD | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Delco-Remy D-1406- 1116522 Ignition switch pictures. Not that looking at these pictures will change the part number, but the terminal locations are key. Pun intended. Brad Wrench Fetcher, PhD | | |
