3 members (Otto Skorzeny, dt235sd, Rusted Nut), 80 guests, and 2 robots.
Topics128,048
Posts1,055,664
#1121749 08/30/2015 9:34 PM
I just took my 53 out for a ride around the neighborhood and shake it down and the Speedo doesn't work, I pulled the Bullet out of the trans and the steel gear is fine but looking into the hole the gear on the tail shaft is worn out, It appears to be some sort of plastic, I haven't had much luck finding any online, any suggestions?
Do like what I did. Find another trans and change the tail shaft.
