1 members (k2handyman), 74 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#1121588 08/29/2015 8:19 PM
On a electric choke which way does the spring move then heated, does it tighten or loosen? Every time I think I have the choke set, the next time I start the truck up it goes to no choke, slow idle, but after it runs a while it goes to some choke which makes the truck idle faster. It is a after market choke ,NAPA. Went to electric because of electric wipers. HELP 53 3100 root
root #1121591 08/29/2015 8:31 PM
Riding in the Passing Lane
The choke should heat up & open the butterfly straight up & down. You must have something backwards. I have had problems with the choke comeing back on but that is in real cold weather when the fan blows cold air on it.
1972 Chevy c10 Cheyenne Super
root #1121614 08/30/2015 12:53 AM
Carburetion specialist
You might find this article interesting:
http://www.thecarburetorshop.com/Automaticchokes.htm
Jon.
The Carburetor Shop
root #1122323 09/03/2015 2:36 AM
Wrenchbender and carbking thanks, I when back and checked the choke and reset it to just closed. Now the next time I drive it we,ll see if it works right. 53 3100 root
root #1123740 09/11/2015 9:52 PM
Finley got the choke set right. The spring on the electric choke was going the wrong way. Looked at the water choke that came off and it was wound going left and the electric one was wound right, so remove the spring turned over reinstalled now everything is good. root
