8 members (cmayna, baldeagle, Bill Hanlon, Leo, Hotrod Lincoln, Mike in Sycamore, Gdads51, 1955 1 Series),
120
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,280 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | I use ethanol free gas in my '59 235. My usual supplier ran out so I Bought some from the local airport. What they had was 100 octane. Is there any reason not to use such a high octane fuel in my truck? I don't know much about octane. What I have heard is that the higher the octane the lower the volatility of the fuel.Is that correct?---Jack | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Expect less power and fuel economy from the 100 octane in your engine. Try this article: http://www.thecarburetorshop.com/Octane.htmJon Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Aug 2015 Posts: 6 New Guy | | New Guy Joined: Aug 2015 Posts: 6 | In my 350 I use octane books in it regularly,i like the way it runs on such..I also use lead substitute with good results. | | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | What are "octane books"? I think you may have meant "octane boost" If so is there something that does the opposite? Some thing I can add to lower the octane.---Jack | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | You probably had some of your regular fuel in the tank when you added the 100 octane stuff so I would just drive it. Carbking's article points some issues that shouldn't affect your 235 too badly. Hopefully your supplier will have the E-Free when you need to fill up next time.
SimS | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Come on guys, no matter what BP says about their fuel, it's not going to 'Invigorate' your 235. Aviation 100 - 130 octane fuels are and were formulated with a low vapor pressure to cope with the altitude changes and the requirements of high compression air craft engines. It did't give them more power any more that it will give your Stovebolt more power. It simply prevents vapor lock or pre-ignition. Your low compression stovebolt engines needs nothing more than a regular grade of fuel to run at their peak performance level when they are kept in tune. There is nothing wrong with running the E-10 fuels in your Stovebolt and no need to gunk up you combustion with octane booster additives. High levels of alcohol such as E-85 or straight alcohol will cause problems with older seals, diaphragms and alloys, but most of the materials that are on the market now are resistant. E-10 is not that high of a concentration that it would eat away your engine parts.
99% of the fuel being pumped today is an alcohol blend and millions upon millions of cars throughout the world run it on a daily basis without falling apart. So...lets get real and start looking elsewhere if our Stovebolt misses a beat or won't climb the hill to home.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | High Octane is for High compression(we ain't got much). Slower burn to prevent pre-ignition. Won't hurt. And it won't help. A lot of air craft engines are air cooled. They tend to run hotter than water cooled. Typical hot spot for air cooled is the exhaust valve. It can light off the incoming air/fuel chsrge and cause pre-ignition. So high Octane for them. Slower burn and lower combustion temps might help at 12:1 but we see something like 7.5:1 so not gonna do much for us. Lower temps means less working pressure to move the piston. So less work per gallon means worse fuel mileage. Match "octane rating" to compression. Low for low compression engines( like truck and lawnmower) and high "octane rating" for high compression(like modified engines and air cooled motorcycle).
Steve H
