3 members (klhansen, 3800GUY, 1 invisible),
63
Mod | | | Forums66 Topics128,153 Posts1,056,847 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | If your ready for a new wiring harness,"Google" Rhode Island Wiring. "They' state that wires are color-coded,cut,and soldered to spec's,both cloth and plastic.depending on original application. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | They make excellent harnesses.
The cloth harnesses are higher-priced than the later plastic harnesses.
I have found that the lower-priced plastic harnesses from Classic Parts (truck parts) are high quality and match the original harness quite nicely. | | | | | Joined: Aug 2011 Posts: 228 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 228 | Classic Parts has several harnesses. The only one designated for stock replacement is # 52-024. (51 GMC, 12 volt, Alternator)
Tim, is this the harness you are referring to? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | A little bit of confusing description by Classic Parts. "Replaces original perfectly", but not perfectly original appearance. I think that GMC went to plastic/taped harnesses in 1954. Earlier GMC harnesses were most likely cloth covered (as were Chevrolet's). I do not see Classic Parts (or Jim Carter) listing cloth braided covered harnesses (they both use to lust them - probably too expensive to keep in stock?). | | |
