| | | Forums66 Topics128,089 Posts1,056,010 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | The oil wick is missing in the starter for my 38. Can I just pack some felt down the little tube? Or is there an illustration for this item on a starter diagram? Thanks in advance. | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | There were two different versions of starter end plates used. One was just the casting with a machined hole and oil wick the other had an actual bushing. On either type you need to check for play, especially if you have the non-bushing one. Any felt, oil wick material that will absorb and hold oil will work. If you cant find something let me know. I keep it in stock. Thanks Ken | | |
