3 members (Lightholder's Dad, Charles in CA, Philipj), 63 guests, and 2 robots.
Topics128,154
Posts1,056,838
Members48,456
Page 2 of 2 1 2
Sir Searchalot
Sir Searchalot
Today I have lived a thousand years. My heart soars like an eagle.
U
U Offline
That is quite Thomas Stearns Elliott-esqe, there bartamos.
I'll format some observations later that may help the next fuelish problem another bolter may have.
Brad
Wrench Fetcher, PhD
Now I'm all jealous! Yours is running and mine is parked in a storage unit. Until Sunday....Then, I'm gonna get some work in on it.
Sir Searchalot
Sir Searchalot
Chief Dan George-esqe. B.C., Canada.
U
U Offline
My plan this weekend is to:
1) Leave the carburetor alone,
2) Put the Oil-bath air cleaner on,
3) Connect the headlights & single taillight wiring (that is already in place),
4) Clamp the exhaust & muffler down more securely,
5) rig up something to hold the tag,
6) Hang the door back on the hinges,
7) Put the seat in, and
8) take the owner for a ride...
Brad
On-topic Edit- when I get to the point of adding an in-line fuel filter, where is recommended? I like between tank & fuel pump...
Wrench Fetcher, PhD
Sir Searchalot
Sir Searchalot
1.Between Tank and fuel pump, best.
2.Between pump and carb only...Nope
3.Both, OK.
If filter built into carb, just no. 1.
You forgot number 9. Get insurance.
U
U Offline
I got liability insurance before I got the truck out of my uncle's barn in 2011 ( I actually called & got it in the field when the brakes went out); value - rated insurance applied for.
Brad
Wrench Fetcher, PhD
Endeavor to persevere! (also Chief Dan George)
Carl
U
U Offline
"I didn't surrender. But they took my horse and made him surrender" (also Chief Dan George)
Alright- looks like it'll have to be tomorrow for the ride; maybe. I have my left headlight & left parklamp working, though.
Right headlight bulb is shot or I have a poor ground.
There is still fuel in the tank; I checked it when I was looking at how to run the fuel sending wiring, which isn't a priority.
"I'm gonna take up teepee livin' if it's like this."
(CDG)
Brad
Wrench Fetcher, PhD
Sir Searchalot
Sir Searchalot
OK OK, any more CDG quotes and this will be moved to Gabville.
Sir Searchalot
Sir Searchalot
"The human beings, my son -- they believe everything is alive, not only man and animals, but also water, earth, stone, and also the things from them. That is the way things are... But the white man -- they believe everything is dead -- stone, earth, animals, and people, even their own people. If things keep trying to live, white man will rub them out..."
Little Big Man?
Sir Searchalot
Sir Searchalot
Yes
U
U Offline
OK; roger that on the quotes- this thread's issue is solved.
My 55.2 235 engine loves the rate of fuel delivery so far.
I will be transitioning to the Electrical shop to figure out why my truck's headlights are cock-eyed; That is if (pause for emphasis on Stovebolt lesson learned implementation)...
...a new headlight bulb doesn't fix it.
Thanks again, Gents-
Brad
Wrench Fetcher, PhD
Sir Searchalot
Sir Searchalot
"Cock-eyed is not a mechanics term, a technical term, a descriptive term and open to various interpretations"
Chief Dan George.
U
U Offline
One light works,
One light don't.
Brad
Wrench Fetcher, PhD
Sir Searchalot
Sir Searchalot
Oh, you mean cock-eyed?
cock-eyed: crooked or askew; not level
Not what you mean, but it is a common problem with head-lights/lamps - they would need adjusting, as described in a Shop Manual.
U
U Offline
Here are pictures of a Airtex 4149 fuel pump disassembled. This is not the 'new' one that didn't work, and I returned, nor the new one that is installed on the engine and working fine.
I just had another 4149 (on the shelf) from my "shotgun" approach to problem-solving days.
Brad
Wrench Fetcher, PhD
Chief Dan George.
Chief Bart Amos, more likely.
Sir Searchalot
Sir Searchalot
wink
Page 2 of 2 1 2
