5 members (Otto Skorzeny, TeW, MickeyP, Brian Moore, 1 invisible), 83 guests, and 1 robot.
Topics128,049
Posts1,055,653
#1123005 09/07/2015 8:30 PM
Hi All,
Only light on my instruments are the red light for high beam, Should there be lights on the dials and guagues? Ta tom
Yep. Are you running on 12 volts? You can pull the sockets out by hand and put in 12 volt bulbs.
Carl
If the gauge cluster is a 55-59 and connected using a original or original copy harness: You may have a grounding issue or the fuse on the head light switch may have blown.
It is best to state what you are working on when you ask a question.
Oops apologies, 12v 1950 3100.
Tom
Yes
You should have 5 bulbs
2 on each instrument, one on ignition
Plus the high beam
Ok thanks, I will get the delve into the back of the dash tonight, see if I can find em. Tom
The problem is most likely in the rheostat within the light switch.
Check the headlight switch as Cletis mentioned, it might just be dialed all the way down which turns the lights off...let us know what you find!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Yep bulbs are good, I will check the switch. I have not noted a light for ignition on, only one I can see is a red light for high beam, which works. Tom
Did you try your headlamp switch as suggested above?
Turn the knob?
....example....
Ignore the LEDs in the video, they are not stock.
The light for the ignition switch is attached to the bracket
...pic...
How did you determine your bulbs are good?
Thanks Guys, The switch did indeed turn to switch on the instrument bulbs. Its just a tad flaky. Tom
