| | | Forums66 Topics128,135 Posts1,056,418 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | Will a 1954 fuel tank and sender work in a 1950? The original tank has a great deal of rust and is going to be replaced. I don't like the fuel line coming out the bottom of the tank in the 1950. The fuel line attaching to the sender seems like a better setup to me. Will the standard fuel pump be able to lift the fuel from the tank?
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | It will fit and it is a better setup. Thats why GM made the change. Trash settles at the bottom and used to get caught in the petcock. With top draw, the trash stays at the bottom. Just modify your fuel line to fit. There is a guy on eBay that sells fuel tanks on eBay for $174. They are made in Canada by Spectra Premium. They are much better than the Asian reproductions. I have bought well over a dozen tanks from the guy | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | It will fit and it is a better setup. Thats why GM made the change. Trash settles at the bottom and used to get caught in the petcock. With top draw, the trash stays at the bottom. Just modify your fuel line to fit. There is a guy on eBay that sells fuel tanks on eBay for $174. They are made in Canada by Spectra Premium. They are much better than the Asian reproductions. I have bought well over a dozen tanks from the guy. Check out item No. 262027484310 on eBay. I just recently bought 2 of the early ones and 2 of the late ones from. His stock may be running low. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | A couple of friends bought Spectra tanks thru their FLAPS Ken. Why would they be running low?? Or are you referring to the price that the guy was selling them for?. If I remember, that was about the price range that they paid for the ones they bought.
dg
Denny G Sandwich, IL
| | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | Will the 1950 fuel pump work or is the 1954 type needed? | | |
