1 members (k2handyman),
74
Mod | | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | On a electric choke which way does the spring move then heated, does it tighten or loosen? Every time I think I have the choke set, the next time I start the truck up it goes to no choke, slow idle, but after it runs a while it goes to some choke which makes the truck idle faster. It is a after market choke ,NAPA. Went to electric because of electric wipers. HELP 53 3100 root | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The choke should heat up & open the butterfly straight up & down. You must have something backwards. I have had problems with the choke comeing back on but that is in real cold weather when the fan blows cold air on it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Wrenchbender and carbking thanks, I when back and checked the choke and reset it to just closed. Now the next time I drive it we,ll see if it works right. 53 3100 root | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Finley got the choke set right. The spring on the electric choke was going the wrong way. Looked at the water choke that came off and it was wound going left and the electric one was wound right, so remove the spring turned over reinstalled now everything is good. root | | |
