9 members (farmallb, moparguy, Opelika Tom, mk72, Otto Skorzeny, Oswald, Hush, RoadsScholar, 1 invisible),
181
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 32 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 32 | Hello, I'm planning to swap my 235 out for a 327 in my 61 c-10. My question is will my original 4 speed work with the small block? Years ago I did the same swap in a 58 with the same 235 4 speed setup and if I remember correctly the input shaft was a little too long and I couldn't get it in gear because the splined part of the input shaft was up against the rear of the crankshaft. I don't know if they had the same transmissions. Hope someone with more knowledge can answer this, I'd like to keep the four speed. Thanks for any help. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Transmissions are the same, only difference is the bellhousing.
Bill Burmeister | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | When you change out the bellhousing, measure your transmission front bearing plate diameter. Make sure the bellhousing has the same diamteter hole so the plate fits snug. This will keep you from buying the wrong bellhousing. I believe you'll need one of these cast number bellhousing: 3815891 (smaller opening) or 3925505 (5 1/8" opening). If you can't find a bellhousing, I can help you.
1959 3100 Apache Fleetside
| | | | | Joined: Mar 2013 Posts: 32 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 32 | Hello, I bought a bell housing a while back from a member here. I knew the 235 wouldn't work, been there done that, and to further complicate things mine has the hydraulic clutch, so it had to be a v8 bell housing with the hydraulic clutch. I'll have to check the numbers to make sure. I just didn't know if the transmission shaft was longer for the six than the v8, which really wouldn't make much sense. It's been too long ago that I did that swap I can't remember exactly what the problem was. Thanks for your replies. | | |
