7 members (1955 1 Series, Bill Hanlon, Otto Skorzeny, rfs56trk, DHedrick, Robert Crandall, klhansen), 123 guests, and 3 robots.
Topics128,087
Posts1,056,399
Members48,442
#1121949 09/01/2015 1:40 AM
Gas Pumper
Gas Pumper
I have been a Chevy guy forever now, but with some of the kits I sell, they are also compatible with GMC engines. Problem is, I know nothing about them. Can someone enlighten me please?
For example,
1940-1953 - Chevy made the babbit 216 and 235
1954-62 - Chevy made the full pressure 235 and 261
(close enough for my purposes)
During those same years, what were the GMC offerings? I know the distributors are compatible but my main concern is the
intake manifold vac fittings. I assume they are the same as Chevy, but I don't even know all the motor sizes. On the distributor, what was the last year they used a short cap/short rotor?
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Deve #1121957 09/01/2015 2:26 AM
GMC 228, 248, 270, 302 were common straight 6 engines (for the straight 6 smaller truck engines).
https://en.wikipedia.org/wiki/Chevrolet_straight-6_engine#GMC_engines
Between 40-62, GMC also made the following straight 6 engines:
236, 256, 426, and 503
Deve #1121962 09/01/2015 2:45 AM
Gas Pumper
Gas Pumper
So...
The 228 would be like our 216 (1939-1953) pretty sure that would have the short dizzy cap/rotor.
The 248 would be like our early 235 (1939-1955) same on the short cap/rotor.
Then the 270 could be like our newer style 235? that one looks like the year would matter as far as its evolution. (1941-1962)
Then the 302 is probably like our 261 (1952-1960) in that its the more highly coveted for its durability and power.
I still do not know what engines had a tall cap/rotor style distributor. Its amazing when you focus on one make how much you don't know about the others.
Thanks Tim!
Deve
The Think Tank
Deve #1121966 09/01/2015 2:57 AM
A GMC person would smirk at your analogies, Deve (as would a mathematician).
All the GMC engines (GMC 228, 248, 270, 302) were full-pressure/high-pressure engines.
I think all had insert rod bearings.
All would be considered full-pressure/high-pressure.
All were supposedly cast with a better/harder alloy/metal-mixture (I think more nickel).
All had superior carburetion, usually Zenith (or, Holley AA-1).
Comparing a 270 to a 235 is interesting.
The only "superior" technology that a contemporary Chevrolet engine had compared to the GMCs was the 58-63 261s had full-flow oil filtration (none of those GMC engines had that technology).
Deve #1121970 09/01/2015 3:05 AM
Gas Pumper
Gas Pumper
Thus why I put the thread here, so a GMC person would post on some of the intricacies. I am sure we have a few people who know this stuff really well. Tall cap distributor vs short cap, bypass oil filter locations and NPT sizes on the intake are of particular interest.
Deve
The Think Tank
Deve #1121972 09/01/2015 3:11 AM
Have you checked out the GMC (vs Chevrolet) distributor caps listed for various years at vendors like Rockauto (if listed, the faster vendor-listings to peruse).
Keep in mind the GMC used positive ground until 12v-neg in 55/56 (depending on truck-size/engine).
Deve #1121974 09/01/2015 3:20 AM
Gas Pumper
Gas Pumper
I don't even know how that would change the (stock) ignition system.
Good idea on RockAuto. But holding out for the GMC guru's here.
Deve
The Think Tank
Deve #1121978 09/01/2015 3:26 AM
"I know the distributors are compatible but my main concern is the intake manifold vac fittings. I assume they are the same as Chevy, but I don't even know all the motor sizes. On the distributor, what was the last year they used a short cap/short rotor?"
"I still do not know what engines had a tall cap/rotor style distributor"
"Tall cap distributor vs short cap, bypass oil filter locations and NPT sizes on the intake are of particular interest."
In an effort to keep this thread on-topic:
It looks like Deve is looking for the following information for 228/248/270/302 engines (throughout their life histories):
1. distributors: short-cap or high-cap and short or high rotor?
2. size/diameter/thread of vacuum port (and or PCV ports - see #4) on intake manifold
3. by-pass oil filter location?
- maybe he is interested in where the filters reside (right-front side of engines, usually); or,
- maybe he is interested in where the ports are located on the block
4. location of PCV ports/devices/fittings/hoses?
tclederman #1121994 09/01/2015 4:47 AM
I think this would help.
1929-1954 GM parts interchange manual buick chevrolet pontiac GMC (CD) in PDF format
Product Description
Vintage GM car and truck parts interchange manual on disc (CD) in PDF format, .Fully autorun, bookmarked with a master menu.
1929 to 1955 parts, there are over 5500 parts that interchange with Chevy, Pontiac, Olds, Buick, Chevy truck and GMC truck in this manual, NOTE, CADILLAC is NOT INCLUDED IN THIS MANUAL
Also included is a 1929-54 Chevrolet illustrated parts manual
Over 1100 pages of rare hard to find info
It would be better if it covered more years. i.e. 1929-1975
