| | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 3 New Guy | | New Guy Joined: Aug 2015 Posts: 3 | I have a new spring but cannot install it such that it opens when hot. Anyone offer any help on this? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Can you move the heat riser manually to verify that it's not stuck? Most that haven't been used for a while are stuck in whatever position they were in.
| | | | | Joined: Aug 2015 Posts: 3 New Guy | | New Guy Joined: Aug 2015 Posts: 3 | yes it moves - but I do not know what position is for heat off and what position is for heat on | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I had the same problem, I even bought 2 just in case I had a bad one somehow, I just think they aren't really calibrated to anything, just some wound up bi-metallic material that is made to look similar enough to the original to get 10 or 15 bucks out of them. Whatever the case, when the counterweight is down the heat is off, when the counterweight is up (the spring is cold) the heat is on. I don't think mine ever had one since I have had it. And I have had it for 30 years, it started and ran just fine at 15 below. So I don't know how important the spring really is. The exhaust is bolted directly to the intake, so conduction is pretty good in that situation, not to mention the flapper inside is far from a tight seal. Also the intake sits over the exhaust for the full length allowing convection on top of all that. I do know if you force the flapper to remain in the heat on condition, the engine runs horribly. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Looking from engine front rotate weight ccw for heat off. If you click on Tim's link above and go to previous page there is a great cross section picture. On my 216 the spring doesn't actually hold the flapper open but is relaxed enough to allow it to open under acceleration.
Ed
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | when you're looking at the spring the closed part of the hook should be facing you ,and to calibrate it you have to hold it and use a long nose plier on the center section and twist it tight or lose so it just opens the flap than when it heats up it will move the flap closed.
Pete | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Whatever the case, when the counterweight is down the heat is off, when the counterweight is up (the spring is cold) the heat is on. Interesting. Mine ('38 car) is just opposite. I verified that when I had mine apart. Maybe they changed somewhere along the line???? It couldn't be that I made a mistake.  If I did it sure runs fine when hot. Heat off position.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | As Pete posted, it's hooked over the stop from the front. From the driver point of view, the theromstate spring is counter clockwise closed, winds clockwise open the butterfly: http://www.pbase.com/dennygraham/image/112537676Looking from the front to the back the counter weight is down in a clockwise position and counter clockwise it's nearly straight up and down: http://www.pbase.com/dennygraham/image/112537670DG
Denny G Sandwich, IL
| | | | | Joined: Aug 2015 Posts: 3 New Guy | | New Guy Joined: Aug 2015 Posts: 3 | Thanks for the help. On my 1948 216 the heat is off with the weight up rotated toward the engine (from the front of the engine CCW) and heat on with weight down. It was flooding real bad after I stopped hot, and I found out the heat was always on. Runs much better on todays 95 degree day with heat off. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | It is interesting to me that GM refers to that spring as an "anti-rattle spring"?!
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | the flapper is in the position to heat the intake manifold when the weight is in the uppermost position, (clockwise standing at the front of the engine), the flapper is in the position to bypass the intake when the weight is down, or the counterclockwise orientation standing at the front of the engine. I can determine this because I have the exhaust manifold in my hand looking at it. If I knew how to post pictures I would. But you are just going to have to take my word for it. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 |
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Aug 2015 Posts: 8 New Guy | | New Guy Joined: Aug 2015 Posts: 8 | Any suggestions on how to free a rusted flapper assembly, or how to remove and replace one? | | | | | Joined: Dec 2013 Posts: 789 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 789 | Hi DocFin, I just finished rebuilding my heat riser. I followed Achipmunk's instructions. Read through the thread he started: Achipmunk's thread Good luck, | | | | | Joined: Jan 2014 Posts: 3,687 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,687 | Mine is stuck in the "heat on/ open" position. How much run time (say...minutes) would it take to produce enough excess heat to affect how well the engine runs?
1951 3100
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 |  If I knew how to post pictures I would. But you are just going to have to take my word for it. Look at the last item in the left-hand column. Harold
Harold Is a restoration ever finished? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Once upon a time I had a locked thread on how to post links to images as a sticky in the 'Bus but it's disappeared.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | yes Harold, but even that assumes even a rudimentary understanding of what is outlined. I don't have that. Peggy tried to help me before. Maybe soon I will figure it out. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The link pointed to on the left doesn't show HOW which is why I had the locked thread that I could point to when necessary. Harold, if you can't figure it out PM me and I'll step you through it. It's not difficult but the process isn't very intuitive.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Here you go Harold. I wrote up V2.0 of the tip. If you still have questions give me a holler.
