3 members (G508, Peggy M, Uncles51), 111 guests, and 2 robots.
Topics128,028
Posts1,055,414
Members48,422
#1113383 07/13/2015 2:30 AM
I have a power brake boost master combo in the original location. mustang II front disc brakes, gm drum brakes rear. i do have residual check valves in place but no proportioning valve on the rear brakes. I have carefully pumped at least two quarts of brake fluid through the system and still no pressure at the pedal. i have adjusted the rear drums and see no air coming out of the tubes as the fluid is going into the catch bottle. Any thoughts?
Are you using a new, used, or rebuilt master cylinder? Some rebuilt MC's are just plain junk, right out of the box. Also, did you "bench bleed" the master cylinder to make sure it doesn't have an air lock in one or both of the chambers?
Yes one should always bench bleed a master cylinder before installation.
Jeffrey
I'll second the bench bleed suggestions.
fore,i've been running a similar set-up,except I have discs on the rear. I have NO proportioning valve,i've had a couple of panic braking situations and have had no issues with rear wheel lock-up.
More pix on Flickr.
Are the bleed plugs on the disc calipers on top or bottom? If the bleed plugs are not installed at the top of the caliper air pockets will form in the piston chamber and no MC pressure. It is possible to install calipers on the wrong side which will cause the bleed plugs to be on the lower end of the caliper. If this sounds a little convoluted I apologize maybe Hotrod will explain it better.
Tim White
49 Chevy panel
91 Jeep YJ
Gas Pumper
Gas Pumper
You can also get Speed Bleeders for each corner. I really like how they work and it saves me from needing another person to bleed brakes properly.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
I also use speed bleeders, but a one-person bleed job is also quite easy using this $6.00 one-person brake bleeder kit.
I've got the same bleeder Tim. It works great. I also got this kit for bleeding the master cylinder. I like it as well.
http://www.classicperform.com/Store/Tools/CPBK.htm
Dennis
40 Chevy 1/2 ton
got em bled, my wife helped out since my son had football practice, just gotta hook up the vacuum line to intake/booster.
gonna rub it over to the muffler shop next week for exhaust, then some new wheels n tires - should be ready to roll!
bleeding seemed to go better after I ran a tube from the bleed screw into a bottle half full of fluid so no air got back in before i got the fockers closed. sorry I'm rambling, scotch is talking now thanks for your help and advise.
