2 members (Oswald, Wayne67vert), 107 guests, and 2 robots.
Topics128,060
Posts1,055,839
Members48,427
#112119 12/16/2004 11:05 PM
I
Junior Member
Junior Member
I Offline
I'm looking for a good compressor that I can do a little painting with but doesn't cost an arm and a leg. I'm not a professional painter and don't want to be. Anybody have any suggestions?
Thanks, Ivor
63 chevy short/fleet 292/4speed
under construction
#112120 12/17/2004 12:24 AM
I have had two Cambell-Hausfield 60 gallon 5-6 hp(yeah right) compressors, one I had ten years & this one is getting close to ten. They sell at Tractor supply, Lowes, Harbor Freight, Sears has a siimilar unit. Run about $400+, but you can paint, impact etc. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#112121 12/17/2004 4:35 AM
I live in the KC area and recently purchased a Cambell Hausfeld, 6.25 HP, 28 gallon air compressor from Lowes. It cost $288.00 plus tax. It is rated at 7.4 SCFM @ 40psi and 6.1 SCFM @ 90psi. It is the new upright tank unit that takes up very little floor space. I was hoping this would fit the bill for my sand blast cabinet which recommends 9-12 SCFM @ 90psi. Unfortunately, it was unable to keep up while sand blasting.
A few days later I purchased a Husky, 7 HP, 80 gallon, 2-stage, 220v air compressor from The Home Depot. It cost $869.00 plus tax. It is rated at 14.3 SCFM @ 90psi which is better suited for prolonged use such as sand blasting.
The reason I explain both scenarios is due to the fact that there are so many options on HP, tank size, voltage, etc. I suggest deciding what your most taxing activity will be and determine the required SCFM @ PSI requirements in deciding which air compressor to purchase. I shopped around at Lowes, The Home Depot, Harbor Freight and Cummins Tools to see what each had to offer. Max Tool (www.maxtool.com) is another source for air compressors.
Another consideration is the power requirements. Many of the larger units require 20-30 amp circuits with a 220v plug and conductor feed from the service panel. I noticed The Home Depot is offering a pretty nice pnuematic air tool set, valued at $200, to go along with their $200.00 air compressor. Sometimes these little add-ons can help justify the purchase.
Best of luck during your search. With a little patience and due diligence with your research, you will certainly find the air compressor that best fits your primary compressor needs.
#112122 12/17/2004 11:10 AM
shucks has cheap smaller ones for 100. to 150. i have a 1 hp. sears with 6 gallon tank iv had for over 30 years and have painted over 30 cars hobby its baerly big inuff but dose the job runs air tools two and is 110 volts sounds like you dont need one any larger
