4 members (elhippie64, Leo, Otto Skorzeny, Gone), 60 guests, and 4 robots.
Topics128,180
Posts1,057,157
Members48,464
Taking manifold off of 216 to repair the original heat-riser and I'm debating doing a multi-carb set up. Looking to see if this is worth doing? I hear these multi carb set up make the engine run smoother, a slightly better throttle response and improved MPG!
My concerns are:
1) Are the claims I've stated above accurate?
2) I do not plan to use a duel exhaust manifold; I plan to stick with the original single exhaust manifold if possible??
3)How reliable/ finicky are these multi carb set ups..a reliable driver is desired--do they require constant tuning?? I plan to use the carbs designed for the 1940 216 engine (not sure the model #, sorry)
4) What performance differences/ characteristics are there between the 2x1/ 3x1 vs stock 1 set up. What can I expect from each? (would like to maintain or improve my current MPG)
FYI **I live in the mountains so pulling on extremely steep hills is part of the terrain here** Truck is a 1940 original in all specs and design,I plan to maintain that with the exception of this upgrade
OK those are my concerns and goals with this project, lets hear what you think, Thanks everyone grin
How much hair do you have? If you're not bald, get a close shave now- - - - -it will save a lot of anguish and pain from pulling it all out.
Dual (or triple) carbs on a stovebolt are nothing but eye candy. They're totally useless, and you'll have nothing but problems, particularly on a 216. Duals- - - -maybe- - - -on a beaned-up 261. The Corvette 3-carb setup on the 235 was mostly for show, and that one was the product of major R&D work by the GM engineering department. I can't think of anybody's 3-carb setup that will fit a truck, too much stuff in the way of the rear carb.
Buy a Carter YF single carb and you will have a smooth idle and plenty of carburetor.
If you really want more performance out of your truck, switch to a T-5 transmission and a 3.73 or a 3.90 rear end.
You will be amazed how this unleashes every single horse power in an inline six! You can still pull stumps, and cruise at 70 MPH. You may even be able to cruise at 70 MPH while dragging the stump.
How, you ask? Having 2 extra gears keeps you in the optimal power range of your engine at every shift.
Carl
Carburetion specialist
I LIKE multiple carb setups!
Having said that, AND read your parameters, don't do it!
With a perfectly stock engine, and dual stock carburetors, you can expect (IF YOU DO IT PERFECTLY):
(A) a slightly smoother runing engine
(B) maybe 5 extra horsepower at wide open throttle
(C) maybe 5~8 percent better fuel economy
(D) expenditure of several hundred dollars
Now, if you are LESS than perfect:
(A) a rougher than normal idle
(B) up to 10 LESS horsepower, expecially at part-throttle
(C) up to 25 percent LESS fuel economy
If you want to change exhaust, cam, ignition, and go with smaller carbs; you could see better results.
But I would agree with the gentleman (Carl) suggesting the transmission change (to a point, don't know about 70 MPH pulling the stump wink ).
And given your location, I would prefer a single original W-1 over the YF. The reason is your location. The W-1 has a mechanical power system while the YF has a vacuum power system. On a truck doing towing in the mountains, the mechanical system is superior (opinion).
Jon.
The Carburetor Shop
Crusing in the Passing Lane
Also need to provide carb heat of some sort, exhaust or water.
Jon.
Good point on the hills, Jon. I'm strictly a flatlander around here.
I will get back to you on dragging the stump at 70 MPH. smile
Carl
If you REALLY want to do it. Pull all the original stuff and put it in storage. Purchase aftermarket intake and dual exhaust and try it for a while. If you don't like it put the stock stuff back on and Craigslist the dual set up to recoup some of your expense.
