4 members (NJC, Otto Skorzeny, Steveoreno, 1955 1 Series), 92 guests, and 4 robots.
Topics128,192
Posts1,057,234
Members48,465
I have two different length horns in the '37 1/2T - Town and Country horns? We have applied 6V and get a single "thump".
Is there any wiring diagrams our instructions out there for rebuilding these horns?
~Justin
1937 Chevy 1/2-ton
"Wylburr Clyde"
More pictures on Google
My Grandfather bought it new and Dad drove it through highschool. The 3rd & 4th generations put it back on the road on 8/8/2015!
Ex Hall Monitor
Ex Hall Monitor
Before '39 they were simply called accessory horns. Try cleaning the contacts. I'm no expert but what happens is when you complete the circuit by pressing the horn button an electromagnet is powered up with pulls the diaphragm in one direction. At full travel a 'nub' on the diaphragm makes contact with a spot that breaks the circuit allowing the diaphragm to go the other way. This happen really fast and the back & forth is what makes the honk. If you're getting a single thump the nub isn't making good enough contact so the diaphragm is being held to one side instead of vibrating back and forth.
Hi Tiny,
Thank you fort he explanation. This is what I thought when I had everything open.
The contacts on this horn appear to be in the "black box" mounted to the bracket. I thought we had cleaned them. I will pull them apart and do some resistance checking...
~Justin
1937 Chevy 1/2-ton
"Wylburr Clyde"
Ex Hall Monitor
Ex Hall Monitor
There's a dome on the back of the horn with a single screw in the center. Remove the screw & dome to expose the workings.
The "black box" on the mounting bracket is the horn relay. It's needed to control the heavy current needed to sound the horns. The horn button triggers the relay.
As Tiny says, the vibrating contacts are under the cover on the back of each horn.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
