| | | Forums66 Topics128,170 Posts1,057,033 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Gentlemen
I just rebuilt one of my front hubs because the drum was binding a little. Cleaned everything out made sure it was lubed up nice. Put everything back together and now the spot is still there. It is at the same point in rotation every time. Can those drums bend? What is my best option or any suggestions. I have put a lot of work into it
Sometimes you're the window Sometimes you're the bug
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Is this the same hub with the loose balls in the bearing? If so, that bearing is no good. Also the hub is one piece.
With regards to the brake drum, they will usually bind more in one spot because they are not perfect. that is not a cause for worry. | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Thanks. So what is the best way to adjust the brakes?
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | |
