9 members (King Kielbasa, Hotrod Lincoln, Otto Skorzeny, stlcardinalsguy, DennisM, Wayne67vert, kades51, MickeyP, 1 invisible),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | My son sprayed his 53 chevy frame last nite. in his garage with por15 (good stuff) but one thing he did not do was put enough ground sheets down..(he's a first timmer).Well the overspray came down and discoloured part of his floor. Is there anyway he can clean this up? any and all information would be greatly appreciated. thanks
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Well, I hope you are mistaken about the spraying Por15. The specs say to absolutely NOT spray this paint because of some very SERIOUS health side effects. Apparently the stuff can turn you lungs to stone with a single breath and should NEVER be sprayed. Your son might do better reading the can next time. (If there is a next time for him)
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jan 2002 Posts: 45 Member | | Member Joined: Jan 2002 Posts: 45 | Talking to the guys at the body shop...that is the impression i got that you have to be careful in using that stuff...breathing mask etc.
Starrider | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | I've found that getting that stuff off of where you don't want it is a booger. On raw concrete I'll bet muriatic acid is your only hope - etch off the top layer. Have you considered just epoxy painting the whole floor? With a nice POR base, it won't rust  . | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If the floor is cool, it might not be set up yet. Try some lacquer thinner, it's your only hope short of muriatic acid.
Fred 52 3600 69 C-10
