4 members (2-Ton, 78buckshot, TUTS 59, Wally / Montana), 80 guests, and 2 robots.
Topics128,060
Posts1,055,835
#112039 01/17/2002 3:47 PM
My son sprayed his 53 chevy frame last nite.
in his garage with por15 (good stuff) but one
thing he did not do was put enough ground sheets
down..(he's a first timmer).Well the overspray
came down and discoloured part of his floor.
Is there anyway he can clean this up?
any and all information would be greatly
appreciated.
thanks
1946 chevy 1/2 ton panel
1937 ford coupe
#112040 01/17/2002 4:22 PM
Well, I hope you are mistaken about the spraying Por15. The specs say to absolutely NOT spray this paint because of some very SERIOUS health side effects. Apparently the stuff can turn you lungs to stone with a single breath and should NEVER be sprayed. Your son might do better reading the can next time. (If there is a next time for him)
54 3100 with 235
62 flatbed dump C60 with 261
#112041 01/18/2002 6:00 AM
Talking to the guys at the body shop...that is the impression i got that you have to be careful in using that stuff...breathing mask etc.
Starrider
#112042 01/18/2002 12:17 PM
I've found that getting that stuff off of where you don't want it is a booger. On raw concrete I'll bet muriatic acid is your only hope - etch off the top layer. Have you considered just epoxy painting the whole floor? With a nice POR base, it won't rust wink .
#112043 01/18/2002 6:17 PM
If the floor is cool, it might not be set up yet. Try some lacquer thinner, it's your only hope short of muriatic acid.
Fred
52 3600
69 C-10
