| | | Forums66 Topics128,118 Posts1,056,302 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | I was wanting to lay my AD cab on its back so I can work on the bottem of it. I have the front floor board cut out of it. My plan was to flip over to its back on to a piece of plywood on the rear part of the frame. Is the cab strong enough to handle laying like this???? Thanks :confused:
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces 2000 GMC Serria 1500 SL 4x4
| | | | | Joined: Jun 2000 Posts: 738 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 738 | Mallard, When we did our 51, we layed it in all directions. We decided that the best way was on it's firewall. That area will take the weight of the cab with out damage. It is so rounded on the back and if you dent the sheetmetal then it will be difficult to straighten. (more work). | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Mallard When you do the front floor(and cab mount i suspect) it needs to be bolted to the frame to do it correctly.After the floor and what ever else you change is done mount the doors and stuff to see if they still close well. Than i would just put it on the firewall to do the finish welding,the back of the cab will dent .Try to do most of the welding inside the cab and seam seal the underside,just looks neater in the end after you put a mat or carpet in. | | |
