8 members (cmayna, baldeagle, Bill Hanlon, Leo, Hotrod Lincoln, Mike in Sycamore, Gdads51, 1955 1 Series), 120 guests, and 1 robot.
Topics128,113
Posts1,056,280
Members48,439
#112034 12/31/2001 4:34 PM
I was wanting to lay my AD cab on its back so I can work on the bottem of it. I have the front floor board cut out of it. My plan was to flip over to its back on to a piece of plywood on the rear part of the frame. Is the cab strong enough to handle laying like this???? Thanks :confused:
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces
2000 GMC Serria 1500 SL 4x4
Joy Offline
Mallard, When we did our 51, we layed it in all directions. We decided that the best way was on it's firewall. That area will take the weight of the cab with out damage. It is so rounded on the back and if you dent the sheetmetal then it will be difficult to straighten. (more work).
Anonymous
Unregistered
Anonymous
Unregistered
Mallard When you do the front floor(and cab mount i suspect) it needs to be bolted to the frame to do it correctly.After the floor and what ever else you change is done mount the doors and stuff to see if they still close well. Than i would just put it on the firewall to do the finish welding,the back of the cab will dent .Try to do most of the welding inside the cab and seam seal the underside,just looks neater in the end after you put a mat or carpet in.
