| | | Forums66 Topics128,090 Posts1,056,020 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I just got my carb back from a rebuild and they sent back three new gaskets. Two thin ones and one black one just shy of 1/8". All have smooth inner circumferences but the one I got from JC has four "notches" evenly spaced on the inside. It is thicker like the black one. Do the notches have anything to do with vacuum and which one should I use? Thanks in advance. Steve | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | What number YF? Sounds like your referring to the base gasket? Look at the base of your carb Don't cover the port ...example... | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Gus, it is a 964S Carter Yes, the base gasket. | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Tim, that is the same kind of gasket I got from JC. | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Gus, I looked at the bottom of my old roch. and the Carter and they both have a small hole which must be the port you refer to. The gasket that Tim shows which is the same as I bought from JC allows that hole to remain uncovered. So that must be the correct one. Am I right? Steve | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think you are right, Steve | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | The correct mounting gasket for a Carter 964s is Carter 1A-41.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks Jon. Where would I find one? Would the one I got at JC work as a substitute? Steve | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Steve, Here are Carter gaskets from Carbking's website (I think). See if the gasket you have fits the base of your carburetor. If it does, and a slot lines up with the hole/holes in the base of the carburetor, use the gasket you have. It is correct for you to be careful - do not let any of these posts scare you. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Yes, I've been useing walker kits from autozone
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks Tim, I'll take your advice and use what I have since everything lines up. Steve | | |
